I have crucicble/fisheye installed on linux as a service, but the service does not read the FISHEYE_INST directory. It works if I start it by manually running the start.sh script. I have FISHEYE_INST defined in /etc/environment. Is there a way to make it work with the service?
Hi Jeff,
Please make sure that the file /etc/environment is with root user and group.
Also you can add an export line in the init.d script used to start FishEye.
Regards.
The /etc/environment is as root, but that didn't seem to work. I just added an export to the init.d script and that did the trick, thanks.
