Is it possible to split a Crucible review?
SAM-Harman November 27, 2018
We reached file / revison limit in an important review (400/800).
Is it possible to split an existing review into multiple smaller (less files) reviews, keeping all comments which are posted by reviewers already?
Alternatively a review copy/clone feature could work too. Does anybody know if this is possible?
Felipe Kraemer
November 28, 2018
Hello @SAM-Harman,
While it is not possible to split a review in multiple ones, it is possible to increase the number of file revisions allowed in a review by configuring the crucible.review.content.size.limit  JVM System Property. The default value is 800.
However, as mentioned in this document, a higher limit will allow larger reviews, which might potentially slow the instance down.
I hope this helps!
Felipe
SAM-Harman November 28, 2018
By performance concerns we do not want to increase the limit.
Copying/cloning a review is not mentioned anywhere, do you have an idea?
Thank you!
Werner
Felipe Kraemer
November 29, 2018
Hi Werner,
Cloning / copying a review is not possible.
For instance, if that was possible, wouldn't that result in having two exact same reviews that reached the file revision limit? The only difference would be their key...
Felipe
SAM-Harman December 3, 2018
Hi Felipe,
if we could clone a review, it could be possible to remove some files from origin and to remove other files from clone. Afterwards to add  more versions of remaining files to origin and to clone.
Thank you for your feedback,
Werner
Felipe Kraemer
December 3, 2018
Hi Werner,
At this time, cloning reviews is not yet possible in Crucible.
I have suggested this to our development team, and you can track this suggestion here:
CRUC-8362 - Be able to clone reviews
We would strongly encourage you to both vote and comment on this issue to offer your feedback and increase its visibility with our developers.
Please see the Implementation of New Features Policy document for more information on how Atlassian chooses which suggestions to implement.
Have a great day!
Felipe
