Is there a way to persist crucible interface settings?
Joseph Duke
March 19, 2014
Is there a way to persist/save settings such as sort order on a column? In a number of my views, I like to see the newest item first instead of the oldest. I can change the order of the column (seems like I have to click twice, once to get it in ascending and the second to get it in descending) but it would be great if when I go into that view, it is already sorted in my preferred manner.
If this isn't available, can this be considered as a request to add it? ;-)
Joe
Piotr Swiecicki
March 20, 2014
Hi Joseph,
I'm afraid such settings are ephemeral and are lost when you leave the page. But please notice those pages are bookmarkable, e.g. https://fisheye1.atlassian.com/cru/?sort=owner&order=descpage would always show review dashboard sorted by owner in descending order. You could use bookmarks as a workaround perhaps?
If you want to raise a feature request feel free to create an issue in https://jira.atlassian.com/browse/CRUCproject.
Hope that helps,
Piotr
Joseph Duke
March 20, 2014
Thanks for the quick answer. I think I'll submit a feature request.
