Hi, Does Crucible help in Peer Code Review of COBOL Code?
Diana Jenosh
September 4, 2018
Understand that Crucible is a tool for Collaborative Peer Code Reviews.
Can it be used for COBOL and other mainframe languages Code reviews?
Diana
Felipe Kraemer
September 4, 2018
Hi @Diana Jenosh,
As COBOL source code is written in textual files, you can surely review them using Crucible.
Please let us know if you need any further clarifications.
Felipe Kraemer
Diana Jenosh
September 6, 2018
Many Thanks @Felipe Kraemer for your reply. I assumed so, but was thinking loud to check if any known issues are there.
But, doesn't it need to take the Syntax/ grammar at all? Atleast to highlight, keywords, constants, variables etc.?
Felipe Kraemer
September 7, 2018
Hi @Diana Jenosh,
If by any chance the syntax is not highlighted automatically, please have a look at these documents:
I hope this helps!
Felipe
