SSL certificate problem: self signed certificate in certificate chain
Alex Hurd July 22, 2022
I have followed the instructions in the following link based off the error I receive when trying to connect to link to a bitbucket repository in my air gaped environment (SSL certificate problem: self signed certificate in certificate chain):
https://confluence.atlassian.com/bitbucketserverkb/resolving-ssl-self-signed-certificate-errors-806029899.html
The crucible server is a Windows 2019 server with GIT 2.37.1.
The Bitbucket server is a Red Hat Enterprise 8 server with GIT 2.31.1.
We have our own CA and the keystore and truststore have both the RootCA and the bitbucket.crt listed in the chain.
I still receive the same error when trying to use http(s) for the Git Authentication Style.
Bitbucket version 7.21
Crucible version 4.8.8
This is the solution that seems to work.
  • Re-install the command-line version of git from https://git-scm.com/download/win
  • In the installation, select "Use the native Windows Secure Channel library" rather than the default "Use the OpenSLL Library" option.
https://community.atlassian.com/t5/Bitbucket-questions/Having-trouble-with-a-CA-signed-SSL-certificate-unable-to-get/qaq-p/986135
SERVER
VERSION
4.8.8
