Can we delete dependency issue types in Jira Align ?
Nicolae Victor Rusu
Is there a way to delete dependency issue types in Jira Align ? I can only see the option of "reject", "duplicate" and uncommit depending what status the Jira Align Dependency issue type has
Jamie Giantonio
April 19, 2024
@Nicolae Victor Rusu Yes, you can delete Dependencies. The ability to do this is behind a system role based toggle. You will need to work with your admin team and ask them to enable this. It can be found: Admin => Roles => Select the Role => Program, Manage you will see:
Once enabled, you will see Delete under the "More actions" menu
Tom O'Connor
April 19, 2024
No, there is no Delete option in the dependency flow.
"Delete" is found under more actions and is controlled by role.
Screenshot 2024-04-19 at 6.51.23 AM.pngScreenshot 2024-04-19 at 6.52.32 AM.png
