Is there a way to delete dependency issue types in Jira Align ? I can only see the option of "reject", "duplicate" and uncommit depending what status the Jira Align Dependency issue type has
@Nicolae Victor Rusu Yes, you can delete Dependencies. The ability to do this is behind a system role based toggle. You will need to work with your admin team and ask them to enable this. It can be found: Admin => Roles => Select the Role => Program, Manage you will see:
Once enabled, you will see Delete under the "More actions" menu
No, there is no Delete option in the dependency flow.
"Delete" is found under more actions and is controlled by role.
