I would like to report on flow times from one state to the next and overall flow time of Epics, Features and Stories in Jira Align relating to Themes. How can this be done at all levels (portfolio, program and team)?
Hi Ian,
Two reports come to mind. The first is the Work in Process report. It shows all work assigned to a selected Program Increment by work item State and includes a series of lean metric charts. For each work item type (Epics, Capabilities, Features, Stories), you can view the following:
The second report is the Process Step Cycle Time report. If your organization is using Value Streams or custom States (Process Steps), for each work item type (Epics, Capabilities, Features, Stories), you can view the following:
Let me know if either of these provide what you're looking for!
-Kyle
The cumulative flow diagram (CFD) is a powerful way to visualize flow and bottlenecks. Apparently it is only available for the Work In Process Report. The Work In Process Report seems to be only at the Iteration (team) level, but not available to show across an entire PI? or for a Portfolio? Also, as we define our Kanbans at these levels with Process Steps more than Work In Process, it would be REALLY helpful to have a CFD that tracks against Process Steps for every Kanban. If there is a way to visualize CFD at every level of SAFe flow I have not found it in Jira Align. (I have seen it in other tools so I know it is possible).
@ALEXIS La Joie It is not in JA. Shame. Hope they do have it in future
To see a portfolio-level cumulative flow diagram (CFD) for a given PI, do the following:
To see a CFD for a given value stream or process flow, click on Step View near the top right of the workspace while viewing the Work in Progress by State report. However, note that there is currently a bug impacting this functionality. You can add yourself as a watcher to get updates on it here: https://jira.atlassian.com/browse/JIRAALIGN-3001
Hope this helps.
