Is there a way to know how many licenses are there in a Jira Align instance and how many being used?
Vinay Sharma
January 27, 2022
1) how many licenses are there in a Jira Align instance
2) and how many being used & who are the users, which are consuming these?
Administration>People>Apply Filters allows to filter deactivated User but it does not provide data for the above queries. Pls. share related article/writeup.
2 accepted
3 votes
Heidi Hendry
January 27, 2022
How to count Licenses
Step 1 - Export the user list
Find the user list and export it
Administration > People > More Actions > Export
Step 2 - Identify the default Role for the Connector
Administration > Jira > Jira Setup > Default System Role for New User(s)
(It's usually "Team Leads or Team Members")
Step 3 - Remove any Atlassian Users
Open the spreadsheet file and identify any Atlassian Users by their email address @atlassian.com
Remove them from the file
(Note: For security reasons we recommend that Atlassian users are always deactivated unless they are actively assisting you or your colleagues. Check column "Active User" and ensure they are set to "Deactivated")
Step 4 - Check the Roles
If you are comfortable with Pivot tables, then use a Pivot table to analyse the data.
Otherwise, use Filter/Sort.
Step 5 - Integrated User Licenses
Count the users with the Role from Step 2,
Those are your Integrated User Licenses.
Step 6 - Full User Licenses
Count all the other Roles.
Those are your Full Licenses.
Notes:
  • Integrated Users do not need to be logging in for them to count – they count as an Integrated User regardless of login activity.
  • An account dedicated to only API uses a Full license
Vinay Sharma
January 29, 2022
Thanks @Heidi Hendry @Paul Flynn for the detailed response!
3 votes
Paul Flynn
January 27, 2022
1) Administration>Support>Version
There will be a line that says something like this: Users: full=100 integrated=400
Heidi Hendry
January 27, 2022
This is absolutely correct.
Paul Flynn
January 27, 2022
2) The second part isn't as simple.   I've found the easiest way to determine this is to export all the users and sort them by role.  You have a default role for integrated users (often Team Lead, Team Member, or Default).  Once the users have been exported into excel, I look at the number of Integrated users and then the subtract that number from the total.
Administration>Access Controls>People
More Actions>Export
