Is there a way to patch the work item links using the Jira Align Rest API 2.0?
Hassan Gharib
September 9, 2023
I am able to patch the description, title, and some of the basic fields but I can't find the path to use to patch the work item links.
Specifically, I'd like to be able to add links to predecessor or successor features/epics/ and capabilities.
I'd prefer to not use a put if possible just to make sure I don't overwrite something that I shouldn't.
thank you
Allan Maxwell
September 10, 2023
I don't see a way to update the Predecessor/Successor Links.  Alternatively, you could use the other "Links" ...not the question you asked and they do not function the same, but just throwing it out there:
      "op": "add",
      "path": "/links/-",
      "value":
               "name": "Predecessor Feature",
James Webber
Ah nice - sorry I should have said I can’t get the links that are already there back by API so if PUT rather than PATCH I wipe the existing links
Like Allan Maxwell likes this
James Webber
I couldn’t update links even with Put rather than Patch. There are certain fields you can update via API but it seems links are not able to be updated.
I hope I am proven wrong by someone else on this forum but this is my experience.
