JIRA Align On-Premise: Features & Limitations
Marta Alberto April 1, 2020
Dear,
Which are the features of the JIRA Align on-premise version?
Is there available some public documentation where we can check the capabilities of the on-premise version?
Moreover, i would like to ask about known technical/functional limitationson of the on-premise version.
Many thanks in advance!
2 accepted
Peter Jessen
April 1, 2020
Hi @Marta Alberto,
The two versions are identical.
In order to be eligible to purchase Jira Align in an on-prem version, your company must meet certain criteria specified by Atlassian.
If at all possible, I would recommend your company go with the cloud version. Support is much easier and upgrades every two weeks are automatic. If you go on-prem, then you are dealing with a delayed upgrade path (as shown in the link @Tom O_Connor provided, as well as a potential need to self-upgrade if your security team doesn't provide Jira Align Support access through your firewall to upgrade your instance.
In addition, the cloud version automatically adjusts based on demand/load. In my experience, on-prem instances are often suffer from performance issues due to the hardware/bandwidth provided.
Peter
Many thanks for your answer!
Like Peter Jessen likes this
Tom O'Connor
April 1, 2020
All release notes, both for SaaS and On-Prem are located here:  https://agilecrafthelp.zendesk.com/hc/en-us/articles/235943887-Release-Calendar
