Jira Align Standard vs Jira Align Enterprise
Roman Mural
What is the global difference between Jira Align Standard and Jira Align Enterprise?
What is the global difference? Can you please tell me whether it is worth taking Jira Align?
Explain the difference between these items:
Epic Financials
Value Engineering
Visioning & Ideation
Personas
Lean Canvas
Enhancement Portal
Mind Maps
Program Meetings
Advanced Kanban
Transformation Management
Portolio & Epic Balancing
Portfolio Financials
Portfolio Meetings
Invest Horizons
Value Streams
Bottom-up Forecasting
Resource Management
Skills Management
Pro & Enterprise Reports Pack
Included Team Tool Connectors
Capabilities
Goals
Strategies
Products
Org Structures
Product Rooms
Portfolio Rooms
Strategy Rooms
Maturity Assessments
Results Trending
That's the difference between Jira Align Standard and Jira Align Enterprise, maybe someone can explain the difference in more detail?
I will be very grateful!
Tina Behers September 18, 2023
@Roman
The short answer is: Standard does not all for the use of strategy, portfolio financials, forecasting, Resource management, Product management, and more advanced transformation support... Easy way to consider "standard" is it supports what SAFe refers to as "Essential Safe" for work management only.
Epic Financials. - The budget, forecast and actual spend for a portfolio epic
Value Engineering
Visioning & Ideation - Vision - company, portfolio or product vision creation -  Ideation - portal to collect ideas or bugs
Personas
Lean Canvas - 1 page business/portfolio plan
Enhancement Portal - see ideation above
Mind Maps -  Jira Align has built in mid maps for visually creating WBS/backlog
Program Meetings - Do not exist
Advanced Kanban - Full kanban capabilitlies in Jira Align
Transformation Management - ability to manage your transformation plans, learning, knowledge articles and standards in Jira Align
Portolio & Epic Balancing - a report used to balance the value & spend across Epics within a single portfolio
Portfolio Financials - Financial plan, forecast & actuals for a portfolio
Portfolio Meetings - Do not exist
Invest Horizons - time boundary for investment (i.e. 1 year, 6 moths, 3 months, etc.)
Value Streams
Bottom-up Forecasting - A foreacsting method available in Jira Align that build from the indidviual & team level.
Resource Management - a process to ensure you have the needed people to do work.. or meet business objectives.
Skills Management ability toi have userrs selct their skills froma set list and rank their skill level..
Pro & Enterprise Reports Pack - Advanced reports for portfolio, strategy, product and enterprise management across execution, resources and financials
Included Team Tool Connectors - Standrad allows connection to 1 and only 1 instance of Jira - enterprise allows you to connect to multiple Jira instances to roll up information.
Capabilities - a work object in a "Full SAFE' WBS
Goals - intermediate goals towards progress on a strategic item
Strategies - Comapny strategy....
Products - the thing your company builds and sells for revenue
Org Structures - Allows you to mimic your HR reporting organizational structure in Jira align to slice reports by organizational unit.
Product Rooms - Consolidated view of a specific product or product suite - views span, work execution, dependencies, risks and releases.
Portfolio Rooms - Consolidated view of a portfolio across Resources, execution, and financials
Strategy Rooms - Consolidated view of the enterprise plan for a specific time period across one or more portfolios.
Maturity Assessments - Custom assessments that can be run from with in Jira Align to measure your organizations incremental progress in agile practices
Results Trending - trend reports on work execution, program & team predictability.
Summer Hogan
Hi @Roman Mural - I don't know about all those features listed above, but there is an Atlassian.com article here that may answer some of your questions. Since your question is so in depth, I would click the "Get in touch" button at the top of the article and get in touch with a product specialist.
