We have Jira Cloud with a Jira Align Integration. We had sync issues with sprints that needed manual correction which has been completed. To check that the sync is working properly, I would like to manually sync one project.
Instructions on 10X: Jira Management Settings:
We do not have a "Sync Board Now" button on the Jira Sprints tab.
Following instructions given during our migration, I tried the following:
Jira Settings > Jira Integration Tab > Select the Project > Select the board to sync > Yes
From that point, I should be able to select the "Run" button however it isn't there anymore.
I'm a Super Admin in our system, I checked with another Super Admin that was able to run a sync on 7/29/22 at 4:48 PM and she doesn't have the "Run" button either.
Where did the button go and how do we get it back?
Thank you!
Rebecca (Becky) Hylek
@Rebecca Hylek , I know you stated you are a Super Admin, but I would double-check the role and verify that you do not have the READ-ONLY MODE toggle on next the to following under the Administration section for the role
JIra Setting
Jira Boards
Jira Sprints
that is the only time I've seen where the buttons to RUN or sync boards would be missing.
Thanks Shannon! We found that was the problem. Everything is good now!
Hi Becky,
you might wish to remove your phone number from your post so that you don't get spam!
If Allan's answer doesn't help you, please reach out to support.atlassian.com and we will help you out.
Hi Heidi! Thanks for the tip, I'll definitely remove that!!!
Becky,
I have noticed that if a Board has no Sprints synced from Jira then you sometimes need to press the Auto-Sync Jira Align Sprints now button to make the Sync board Now button show up. I have not done enough investigation to determine the exact circumstances that cause this, but you might give it a shot.
Allan, I would love to find out more if you run into that again. I've never seen that happen
Usually, several of the buttons on the Sprint Tab disappear when Run Sync Now is pressed and return when the operation completes. I think there may be a certain error where the sync does not complete properly and the buttons never reappear. Pressing the Sync Future Sprints button restores all the buttons when it completes normally.
That is what I believe was happening, but I cannot reproduce now.
