Need to use Solution layer for a portfolio only. How to enable it for that portfolio only?
Vinay Sharma
November 29, 2021
We need to use Solution layer for a portfolio only. How to enable it for that portfolio only and disable it for other portfolios?
Pls. suggest the correct configurations to be done under Administration>Settings>Platform>Solution.
For a Program which does not have Solution level, should have Epic as a Screenshot.pngparent work item not Capability.
Pls. suggest
3 votes
Rich Sparks
November 29, 2021
There may be two parts to your question.
  1. The first is about using the Solution layer in your Team structure. (Portfolio-Solution-Program-Team)
  2. The second is about using the Capability in your Work structure. (Epic-Capability-Feature-Story)
You can have the Solution level in your Team structure without requirement the Capability in your Work structure.
To create a Solution within a specific Portfolio:
Go to Administration
Go to Programs; Click "Add Program"
In the Program Detail Panel, select the Portfolio you want to add the Solution to.
In the Solution dropdown, pick Yes
That will create the Solution. Then when you add new Programs to that Portfolio, you can specify they belong to that Solution.Screen Shot 2021-11-29 at 12.14.46 PM.png
If you want to use Capabilities, you can turn that on for specific Portfolios. Then only those Portfolios will have that extra work layer. And, as you mention in your question, any Features in that Portfolio will have to have a Capability as a parent object, and that Capability will have an Epic as its parent.
To turn on Capabilities for a Portfolio
Go to Platform
Pick "Portfolio Specific Configuration"
Pick the Portfolio you want to use Capabilities
In the "Enable Capabilities" dropdown, select Yes
Vinay Sharma
November 29, 2021
Thanks @Rich Sparks for a prompt and comprehensive response!
