Is there a way for me to map Portfolio Epics to Products?
In foresight, I feel that would be depending on the nomenclature your use. A typical segregation could be Product A which may have Portfolio Epic - 1, 2, 3 and so on. However, there is nothing stopping you from identifying a Portfolio Epic based on your requirement. Note that JIRA may recommend the typical way mentioned above.
I have 10 Portfolios. Each portfolio is dedicated to unique set of products/services. I create a portfolio epic (initiative) that extends the value of 1 or more of the associated products. I would like to associate those specific products impacted to that portfolio epic. It seems there are conventions for defining Products in the tool- I can't find and more information on this however. I don't think using tags is appropriate.
One way could be to evaluate at creating a Parent Product Portfolio Epic (use some agreed naming convention & distinct for each product) --> Tag your existing Portfolio Epics --> Features (Epics) --> User Story ....and so on.
This could be a "hack". There could be other possibilities for executing this better.
