Issue with detail pannel settings
Abhinav Reddy
Is there a reason why the details panels settings in the admin screen is not reflecting changes to fields when we change them? Specifically, I am talking about fields on the capability detail panels setting. We are trying to make the product bundle not required for a capability for one of the portfolios but no matter what we do it is making the product bundle field required for the capability. Can the reason be this is hard coded for our org, or is this a bug in JA?  all other work item fields seem to be working as I would expect in JA. This is only one that does not seem to be working as I would expect so I am wondering if there is customization here that I am not aware of.
Thank you.
Tina Behers
@Abhinav Reddy @Sam Tsubota
When enabled the system is hardcoded to require Epics for all capabilities.
When enabling Capabilities for a portfolio this message is displayed:
"Enabling Capabilities puts a layer between Initiatives and Jira Epics. An Initiative will be associated with Capabilities and Capabilities will be associated with Jira Epics. The direct Initiative and Jira Epic association will no longer be possible. Once Capabilities are enabled, they cannot be turned off.
Capabilities will be turned on for this Portfolio only.
If Multi-Groups is turned on then you should not have a mixture of portfolios that have Capabilities on and off (This could result in unusual reporting rollups)."
INHO the text on this message would be more clear stating "Enabling Capabilities puts a REQUIRED layer between..."
Abhinav - in your instance, unless something changed in the structure in the last 6-8 months, ALL of your portfolios are set up as Product Bundle, Capability, Jira Epic(Feature) and Story.  If something did change and any of your newer portfolios do not have capabilities, do be aware that multi program options between capability enabled and not enabled portfolio WILL skew the reporting.  This also will need to be accounted for in your use of Enterprise Insights (BI)
Hope this helps
Tina Behers
Sam Tsubota
August 19, 2021
@Abhinav Reddy Did you rename the feature work item and product to capability and product bundle in your Jira Align instance? If this is what I think you are referring to then the Product field is a required field for features if enabled (enabled when Manage Products = Yes under Platform -> Manage Portfolio Specifications. See screenshot). You don't have the ability to make it not required.
Abhinav Reddy
Hello Sam,
 Thank you for the reply!
We have only renamed Epic to 'Product Bundle'. Capability remains as Capability in our JA instance.
Thank you.
Sam Tsubota
August 19, 2021
@Abhinav Reddy In the Detail Panel Setting of the Portfolio for Capabilities, is the Required toggle for Product Bundle (Epic) turned off? This will not make it required to assign an epic (Product Bundle) to a capability when you create it.Screen Shot 2021-08-19 at 10.22.16 AM.png
Abhinav Reddy
It has been set to Off, but it isn't reflecting change to the Product Bundle field in the Capability. I have another observation, in the Capability I see the Product bundle is named as Parent Product bundle as shown in the picture. I'm not sure where the word 'parent' is coming from
Sam Tsubota
August 19, 2021
@Abhinav Reddy Since that toggle is set to off it could be a bug. I suggest opening a ticket with Jira Align support to help troubleshoot the issue. As for the field name displaying "Parent", in Jira Align work items a level above in the work item hierarchy are commonly referred to as the parent. On the Capability Detail Panel, the epic (Product Bundle) associated to a capability is the Parent Epic or in your case Parent Product Bundle.
Abhinav Reddy
Got you. Is there a way for Atlassian to hard code it(Product bundle to be required always) for a specific organisation's Jira Align instance?
