Have you added the API Client in ATT Control Center and, if so, what error are you getting?
Im not familiar with API really at all. Do I need software in between them for the calls? Meaning do i need to a scripts that run on a server that will pull info from Jira and push to Control Center?
The absolute most simplest thing you can do use Postman or Curl to execute a single API call directly from your browser.
What is the overarching purpose of the integration?
Ultimately I want a ticket to be created in jira for activate and deactivate and it does it automatically.
