Need help with KANBAN throughput on roadmap (SIMPLE EXAMPLE)
Joe
What is behind this auto calculation?   (NEED HELP)
  • I have set up a test team under a test program with a throughput of 1.
  • I have two features, each with 6 stories
  • I have 6 sync sprints per PI
  • I have my 2 features prioritized
  • I have my 12 stories prioritized
    • top 6 stories in feature 1
    • bottom 6 stories in feature 2
  1. I would expect to have 1 story line up under each sprint based upon a throughput of 1?
  2. Target completion dates look good based upon priority for feature 1
  3. Why are target completion dates in lower priority stories in feature 2?
BELOW ARE FOR FEATURE 1
THESE ARE FOR FEATURE 2
STORY IDTARGET COMPLETION DATE
110/27/23
211/3/23
311/10/23
411/17/23
511/24/23
612/1/23
710/27/23
811/3/23
911/10/23
1011/17/23
1111/24/23
1212/1/23
Allan Maxwell
October 22, 2023
Throughput is measured in Team Weeks, not Team Sprints.  If I am understanding your question correctly, it sounds like you are expecting a throughput of one to result in the forecast completion of one Story per Sprint, but it is (correctly) showing two Stories per Sprint.  I'm also assuming your Sprints are the typical two weeks long.
EDIT: After further investigation, I see what appears to be a bug.  I created this issue with support: ALIGNSP-21429
Joe
Ahh, so I am not crazy?  Yes, I do know that KANBAN measures in weeks, thanks.  Can you give me access to the bug so that I can share with my team?
Allan Maxwell
October 24, 2023
