WIP Limits on features
Linda Redgate
Is there a way to implement WIP limits on the Kanban board for the feature backlog in Jira Align?
Allan Maxwell
July 27, 2023
You can only implement WIP limits on the Feature Backlog Kanban board if you also use Process Flows (depending on when your instance of Jira Align was created and what your admins have configured, they may be call "value streams" or something different).  Process Flows allow you to better map your existing process/framework in Jira Align versus the immutable States (0 - Pending Approval, 1 - Ready to Start, etc.)
You can define Process Flows for Themes, Epics, Capabilities, Features and Stories.  Process Flows can be unique for each Program or they can be shared across all Programs.
Only Feature-level Process flows can have WIP Limits, but every Program can set their own WIP limits for each step in the flow.
Here are some visuals for clarity:
Screenshot 2023-07-27 at 9.40.09 AM.pngScreenshot 2023-07-27 at 9.34.56 AM.pngScreenshot 2023-07-27 at 9.29.54 AM.png
Edvaldo Lima
July 11, 2023
Hi @Linda Redgate
I'm afraid this functionality has been removed from Jira Align back in 2021.
Ryan Reed March 28, 2024
@Edvaldo Lima, Will this be added back into the tool as noted in the articles you reference above?
Also will WIP Limits be added for other levels of process flow (i.e. Theme, Epic, Story)? I would like to note that the current help.jiraalign.com help article to create process flows still says that WIP Limits are available. Can you please ask that this be removed?
@Edvaldo Lima & @Daniel Silverman
Edvaldo Lima
March 28, 2024
@Ryan Reed
According to my research, the WIP Limits functionality was added back on Jira Align v.10.101.
Regarding our 2nd question, adding WIP Limits for other levels of the process flow (i.e. Theme, Epic, Story) is not in the Product's short-term roadmap as far as I can see.
