I have multiple programs set up in Jira Align. There is an Epic which contains features for different programs but I need to be able to show the dependencies, at feature level.
Is this possible? If so, how?
@Linda Redgate dependencies can be managed at multiple levels: Features, Epics and Capabilities (those are the default Jira Align names for those levels, they may have been renamed in your instance.)
The levels at which you can manage those dependencies will be determined in the Jira Align Administration panel by your admins. Below in a snapshot of what is available under Admin > Platform Settings > Team
If you are not able to manage dependencies at any of these levels you will need to work with your admin to have that enabled.
You can find more on Dependencies and Team Settings in help.
