how to create PI in JIra
kbr kbr
June 26, 2023
we are planning Safe agile transition and need help on how to start and required templates in jira
Please helpor share your number to connect and discuss on same
Ahmet Kilic
Hi kbr,
thanks for your question.
From your description, I got that you have started an agile transformation and you're using SAFe as a framework and Jira as a supported tool, correct?
We, Enterprise Agility Team at catworkx recommends to do a workshop to determine your needs. So that we can offer you the best suitable solution.
Depending on your agile maturity you will be informed about Jira Align, Agile Hive, Big Picture or Advanced Roadmap in our agile at scale solutions.
We will offer more than templates, trust me :)
Don't hesitate to reach out to agile@catworkx.com. One of our SAFe Practice Consultant (SPC) would be happy with.
Best,
Ahmet
Enterprise Agility Consultant
