Hi everyone,
I’ve made the Parent field a required field in my Jira project. However, when using the Issue Collector, the form does not display the Parent field, and as a result, the submission fails due to the required field validation.
Is there a way to:
Any suggestions or workarounds would be greatly appreciated!
Thanks in advance.
To display the "Parent" field in a Jira issue collector, you need to ensure it's included in the collector's create issue form. This involves configuring the issue collector to use a custom form and including the "Parent" field within that form.
ATL_JQ_PAGE_PROPS
object.how can I add Parent filed because its not visible in Custom filed see image in my question.
one more doubt I have in this is it possible to remove some unwanted fields from form or set mandatory?
Given what the Parent field is, it is likely not possible to do so. Parent field depends on what you have visibility to see. Collectors are not dependent on having an account, and so no permissions. This is what also prevents them from using "Linked Issues" field or those things that require that.
Adding to what J_Caldwell has said about displaying built-in fields. There are also known limitations about showing required fields to anonymous users. A possible workaround might be to set a default Parent.
Actually I have set parent field mandatory in my workaround, now how can I set default parent in issue collector?
Ah! @Sundram Trivedi After digging little bit, I found that it is not possible, please check below links as reference:
Regarding the default custom field value setting, there is no work around to do so, as Parent Link is a system field which is locked. And also I found another article to set custom field values but it might not helpful for this field.
And for your another query " is it possible to remove some unwanted fields from form or set mandatory?":
To remove fields from the Issue Collector form in Jira Cloud, you'll need to use Field Configurations and their associated schemes. Specifically, you'll need to create or modify a Field Configuration to exclude the desired fields, and then assign that configuration to a Project or Project Scheme.
=> Remove Fields from the Configuration:
Recommended Learning For You
Level up your skills with Atlassian learning
Learning Path
Become an effective Jira admin
Manage global settings and shared configurations called schemes to achieve goals more quickly.
Streamline Jira administration with effective governance
Improve how you administer and maintain Jira and minimize clutter for users and administrators.
Learning Path
Become an effective Jira software project admin
Set up software projects and configure tools and agile boards to meet your team's needs.
