Jira_Insight issue
Vanessa Becker
Hi guys!
Anyone that has done a Insight server to cloud migration before?
I am having an issue whereby i cannot see the import object schema tab on the cloud to import my files on the cloud.
See attached file.
Has anyone had this before?
Marc Koppelaar
September 20, 2021
Hi @Vanessa Becker
This option, unfortunate, doesn't exist in Cloud.
you will have to create your object scheme or schemes from scratch, I know it's a shame and loads of work.
Marc
Vanessa Becker
Hi Marc
It does exist. If the objects are linked to Jira issues you cannot migrate it.
https://support.atlassian.com/jira-service-management-cloud/docs/migrate-insight-cloud-to-insight-in-jira-service-management/
Kind regards
Vanessa
Marc Koppelaar
September 20, 2021
Hi @Vanessa Becker
In the shared link you mentioned there is one very important statement:
All customers who have a license for the legacy Insight app as well as Jira Service Management Cloud Premium or Enterprise Plan should be able to use the Import object schema feature.
So to use or to see the import function for Insight on Jira Cloud a legacy Insight license is mandatory. If you don't have this the import function is not available.
Marc
Like Dirk Ronsmans likes this
Dirk Ronsmans
@Vanessa Becker ,
Also keep in mind that the article you ar quoting is to migrate from Insight Cloud to Insight within JSM.
So not from Insight Server to Insight Cloud.
I would reach out to Atlassian to see if they have a path available as part of the Journey to cloud where you can do a direct migration/import from Insight Server to Insight for JSM (not the app but the builtin Insight)
Like Marc Koppelaar likes this
Paweł Jakimiak
Is it a sandbox?
Vanessa Becker
Hi Pawel
Not sure what you mean?
Paweł Jakimiak
I meant whether you're tried to import data to standard Jira Cloud instance or into the sandbox of this instance (https://support.atlassian.com/organization-administration/docs/manage-product-sandboxes/).
I suspect that you tried to import data to sandbox and it can be a reason why option which you looking for is not available.
If it's not sandbox, you should contact with Atlassian support. I had the same problem on standard Jira Cloud instance and the support helped me.
Despite everything, I'm worried that migration from Insight Server to Insight for JSM in Cloud is not possible with this option. You should recreate manually whole structure of your Insight Serve on Cloud and after that you should use option "Import" which you can find in "Configuration" menu of your schema (Insight -> View all object schemas -> Action next to the schema -> Configure -> Import.
