I don't know about this shared configuration and all please anyone can help me. with the topic " share configuration ".
Hi @Akhil
If you create a project with a shared configuration, you will select an other project as the 'source' of all the schemes to be used by the new project.
Any changes to the schemes will then affect both/all the projects linked to the schemes. So care is needed when amending. But this is also a great time saver when you need to manage lots of projects that follow the same defined process/set-up
Check out:
@Akhil If you have any specific question let us know.
Recommended Learning For You
Level up your skills with Atlassian learning
Learning Path
Become an effective Jira admin
Manage global settings and shared configurations called schemes to achieve goals more quickly.
Streamline Jira administration with effective governance
Improve how you administer and maintain Jira and minimize clutter for users and administrators.
Learning Path
Become an effective Jira software project admin
Set up software projects and configure tools and agile boards to meet your team's needs.
