The blank page problem is real. You open Jira Product Discovery excited to organize your roadmap, only to wonder: Where do I start? What fields do I need? How should I structure this?
Many of you asked for more examples of how to use JPD effectively. Today, I'm excited to announce Pre-built Views—pre-configured views that showcase proven product management frameworks in action, complete with fields, filters, and grouping logic that solve real problems.
Our new Pre-built Views Playground features frameworks that demonstrate JPD's flexibility across key product management jobs:
Prioritization: Multiple framework examples including RICE, MosCow, KANO, $10game
Roadmapping: views tailored for different audiences—executives, engineering teams, and stakeholders
Feedback & intake: Complete workflow showing how to triage ideas backed by customer insights
Resourcing: Lightweight capacity planning and resource allocation examples
Portfolio management: Multi-project views for leadership oversight and strategic alignment
Each view solves a specific Job-to-be-Done while showing how JPD adapts to different ways of working.
Instead of building frameworks from scratch, you can:
Start with proven practices that successful teams already use
Learn by doing with working examples you can customize
See value immediately instead of spending weeks on setup
Discover new approaches that expand your PM toolkit
Explore the Playground in a sample project to see the frameworks
Try different views to understand how each framework responds to scenarios
Adapt what works by creating similar views in your own projects
Customize and iterate based on your team's specific needs
Check out this demo to learn more
This is our first iteration of pre-built views, and we're eager to expand with more templates based on your feedback. Have ideas for frameworks we should include next? Drop your thoughts in the comments below 👇
Known limitations
Currently available for English locales only
Currently set up as a sample project; future versions will support view templates within existing projects
 Jet
13 comments
