@Rohan Swami@Tanguy Crusson Is there any way to create an Atlas Project from Product Discovery? Similar to how you can create a Delivery Project?
As part of our workflow, we want to have an Atlas Project created when a project is moved from Candidate to Planned. Can that be automated or can there be a button that can create that?
March 28, 2024 edited
@Jake Phillips We don't support this at the moment, thanks for the suggestion we'll keep note of it. @Alex Note that the checkbox to populate the epic description will only appear when you create a delivery ticket and not when you add a delivery ticket. Is it still not appearing for you in the create scenario? @Christoph Piotrowski [catworkx] Your site already has the Atlas integration enabled.
Thanks for activating the Atlas - JPD integration! @Tanguy Crusson I've noticed that Atlas fields cannot be selected to be part of calculated files eg. Having the equivalent of a Goal Impact field. Is the a plan to include them?
@Rohan Swami I've created a field that used the original Goal field count as the weight to multiply with goal impact. Now I want to use the Atlas Goals field... But when I try to add it to the formula I don't see it in the drop-down to select it
498 comments
