What are we up to? Public roadmap for Jira Product Discovery
58 comments
Tanguy Crusson
February 13, 2025
@Gina Gould when someone opens a view for the first time we do open the "about this view"menu by default. In this case you're not authenticated so you'll see it every time.
We're actually going to roll out a change so it shows every time someone opens a shared view, and will see how many complaints we get 😅
Like • # people like this
Tanguy Crusson
February 13, 2025
Hi @Kate we have this feature ready already, part of the Premium plan early access program
You can see it here on the public roadmap
Like • Kate likes this
Tanguy Crusson
February 13, 2025
@Matt Hudson are you sure your project access setting (project settings > access) isn't set to "public" or "limited"? If you don't want people to have access to it, you'll need to make it "private"
Gina Gould
@Tanguy Crusson having an option would be nice. So this way if it’s a important view you can set it to pop-up every time or if it’s a view that’s used all the time and doesn’t need explanation then you would toggle or refine the setting that it does not pop-up every time.
Matt Hudson February 16, 2025
Hi @Tanguy Crusson - Yes. The project is set to Private, and the individual views have been shared only with groups that do not include my "Test User"; however, the Test User can still see those views.
Thanks for your ongoing help!
Tanguy Crusson
February 16, 2025
Okay @Matt Hudson I wasn't able to reproduce this 🤔 I think you're going to have to raise a support ticket so we can investigate (you can raise it directly from the JPD project > give feedback > select the option to get help from the support team
Like • Matt Hudson likes this
Arvin Arora
February 17, 2025
Hi @Tanguy Crusson - we started to use JPD for collecting the inflow for product ideas from our SBUs and taking decisions with them. One detail which would be important and very helpful to avoid creating power point slides and work with the management directly using JPD would be to show certain fields on the "bubbles"  in the matrix view in order to immediately understand to which products they refer.
Like • Miroslav Majtáz likes this
Matt Hudson February 18, 2025
Thankyou @Tanguy Crusson
Done!
Celly
Hi @Tanguy Crusson
Here are the 3 things that would bring huge value
for Published Views
  • Integration with custom subdomain roadmap.website.com
  • Being able to Upvote/Comment on Ideas
    • As Guest
    • Registered User (Not Atlassian Account)
  • Configure Published Fields
Tere Pile
* Concern: 5000 row limit, Between Open & Closed this seems like it will become a problem at some point.
* Concern: Engineers not being able to 'add epic to idea' from the software project (w/out license - allowing contributor would work)
* Want: Create 'form' w/individual template & required fields.  A majority we have a few key items that drive the grouping of views and automation.
Like • Lisa McCann likes this
Morten Christiansen
February 27, 2025
Hi @Tanguy Crusson
I just had a look at your roadmap for JPD, and found this task: JPR-13 to support the Atlassian Teams field across Atlas, Jira Software and Jira Product Discovery.
It is in stage Make - what is the expected timeline for this feature?
Thank you very much.
/Morten
Chris Hoppe
March 18, 2025
I'm new to JPD, but I'd really like the ability to change the product timeline view to be shown by weeks or 2 week sprints. Right now, it only does months and quarters.
Additionally, I would like to be able to see and customize the links between ideas, if I could change the color, line type, weight, etc of the links that would help.
John Soukup
March 20, 2025
@Tanguy Crusson I was wondering if the Premium version will have the workflow Approvals feature that currently exists in team-managed projects.  The use case is to have explicit sign-off on a feature's benefit before it can proceed to delivery.
Owen Scott
Hey @Tanguy Crusson my group is eagerly awaiting idea hierarchies—if you need any early testers, please let me know!
Sarin Kanhirapuzha
Hi @Tanguy Crusson - I wanted to follow up on my previous comment to see if there are any updates regarding the public-facing roadmap.
https://community.atlassian.com/forums/Jira-Product-Discovery-articles/What-are-we-up-to-Public-roadmap-for-Jira-Product-Discovery/bc-p/2911343#M3066
IMO, the current public-facing roadmap needs significant improvements before you can share it with clients. I would appreciate an update on this matter, as we are at a critical point for making decisions on external-facing roadmap tools.
Thank You.
Tanguy Crusson
April 28, 2025
@Sarin Kanhirapuzha no update at this stage - we've been focusing on other (also highly requested 🙂) areas. We do plan to revisit this in the future, but not short term.
Like • Sarin Kanhirapuzha likes this
Lisa McCann
Tanguy Crusson
April 28, 2025
@Lisa McCann we're iterating up a lot of new stuff (hierarchies, cross-project views, etc.), this one is one of the next topics we plan to tackle after that. Nothing you, as a community, can do unfortunately - we can only do so much at once 🙂
Dan Driscoll
Hi @Tanguy Crusson - Following up on my January question as I don't believe I saw a reply regarding  JPD and Release aka FixVersion.  Screenshot 2025-04-28 102621.png
Youri REGNAUD May 5, 2025
Waiting for better insights management what will be your advice to manage insights now and ensure a smooth transition to the future insights management features in JPD? (Ideas Type, Jira Desk, …) I make some tests and Jira Desk seems to be a more advanced way to manage feedbacks queues, workflows, and link to JPD…
Tanguy Crusson
May 6, 2025
@Youri REGNAUD we're talking about this in 2 places:
Set up a Jira Service Management queue to receive feedback from customers and internal teams (and how to set up automation rules to do it)
Mark T
It'd be very helpful for our customers, who have JSM portal-only access, to be able to submit comments, vote, and submit new ideas. Voting would be our top priority.
Harrison Ponce
Hi @Tanguy Crusson thanks for the update here! To submit new suggestions or bugs for JPD, how would we do that? I didn't see that JPD has a project in JAC or ecosystem Jiras. Are we able to vote on features to help your teams prioritize them like we can in JAC?
Phil Dalencour
July 16, 2025
Definitely need Android native app support.
Lissa Radman
September 12, 2025
Hey @Tanguy Crusson
We are starting to do discovery on supporting a public facing roadmap using JPD. In reviewing your public facing roadmap I noticed you are using a unique project called JPD Public Roadmap. How do you keep this view aligned with the project your product team uses internally with engineering to track delivery, prioritization, etc.? Do you have any best practices for linking and syncing multiple projects so that the Public Roadmap stays accurate and in step with your internal roadmaps? Also any operational go ya's you have learned.
