Is there a way to filter Ideas in Jira Product Discovery based on Latest comments in that ??
Use case is To filter the Ideas which have latest comments added in that.. There is a field called Updated that can be used to see when was the IDEA last updated , but it will filter out all the ideas that have ever smaller changes done in description.
So can we add or introduce a new field using automation to filter out ideas having latest comments added ??
Hi @Ashish Raina , you can't do this out of the box today but you should be able to achieve this via an Automation rule (update a field when a comment is added). I haven't tried but that should work.
Thanks @Tanguy Crusson for the revert, it am trying it by introducing Automation rule but as of now there is no luck on that. Will try more on this and in case i need some assistance will reach out to the community..
