New ideas & features are usually part of the bigger components that makes up the overall user journey. Is there a way in JPD that help us organise ideas into components similar to ProductBoard?
You can use a custom select field to act as your component/feature and use it in the Group by feature on your view to easily display your ideas based on their linked component/feature
Is this what you're looking to achieve?
Manu | Atlassian Team
