Creating costume formula in Product discovery
Raj Agarwal
July 12, 2024
I've been exploring JPD for product roadmap and prioritisation and wanted to know if it's possible to create custom formulas using IF AND conditionals as I need to assign weights to items based on certain parameters which would be their own columns in the template.
Amina Bouabdallah
July 12, 2024
Hi there! today, formulas cannot be built using conditional operators today. What you have available is mathematical operators: add, substract, divide, multiply.
We'll take a note of your need to have conditional operators for formulas.
Thank you!
the JPD team
