Hi
I am trying to setup a RICE score where the Reach has the following values, 0.25, 0.5, 1, 2, 3.
I do not want users to be able to select/enter any other values.
I have made a new "select" type field and added these values in, but I can't seem to "read" these values as part of a "Expression" field. I thought I might be able to added a custom weighting to the select field, but the weighting only allows for whole numbers and not decimals.
So my question is, what is the best way to make a field that has the values 0.25, 0.5, 1, 2, 3 that the user cannot change AND which can be used in an expression?
Maybe you can just multiply it by 100, and in any calculations divide it by 100.
Here is an example how other user solved this: https://community.atlassian.com/forums/Jira-Product-Discovery/Create-a-RICE-Method-custom-formula-for-JIRA-Product-Discovery/m-p/2513315#M1371
