Daily New Issue Automation
Sing Chen
Hi Community,
Looking to get some assistance with an automation.
The goal is to send a daily email with details of any new issues created in the previous 24 hours. However, what I haven't been able to figure out is to only send the email if there have been new issues created in the last 24 hours.
This is what I have and obviously the lookup has no content if there are no new issues.
Thanks in advance!
Sing
3 accepted
Antonio Valle _G2_
July 19, 2023
IMHO your use case is easily solved with a filter subbscription, as stated by @Sheri Widler
https://support.atlassian.com/jira-software-cloud/docs/manage-filters/
Sheri Widler
Why not use a filter and subscription?
Annie Ioceva _Nemetschek Bulgaria_
This is what I would have suggested:
  • Create a filter such as "created >= -24h order by created DESC"
  • Subscribe the group that needs to receive the emails from the Details menu of the filter
Like Sheri Widler likes this
Tomislav Tobijas
If you wish to proceed with automation, you can construct a condition that will take a look at Lookup issue size. If it's greater than 0, then send an email. Just use {{lookupIssues.size}} smart value and Advanced compare condition.
You can also take a look at the following question/thread: https://community.atlassian.com/t5/Jira-questions/lookupIssues-size-not-working-for-me-when-I-want-to-send-an/qaq-p/2127805
Tom
Sing Chen
Thanks @Tomislav Tobijas ,it's great to have options!
Like Tomislav Tobijas likes this
Sing Chen
Thank you all! 👏
