Do custom field contexts work in JPD projects?
Leslie Barrett
Hello - I know that you can use global fields in JPD projects. What I want to know is whether that also includes creating custom field contexts? Thanks in advance!
Daniel Pierce
Yes, you can use global fields in Jira Product Discovery (JPD) projects, but custom field contexts are currently not supported.
In other words, while you can reuse fields across projects, you can’t define separate contexts for the same field in different JPD projects just yet (assumig that's what you are referring to). Unless I'm misunderstanding what you mean with "context".
Is there any thing specific you’re trying to do something specific with contexts, maybe there is a workaround.
Nikola Perisic
Hi @Leslie Barrett ,yes, these are called global fields. Go to Settings > Products > JPD > Global fields
