As I would assume most groups interested in the new Product Discovery are using Jira Software Company managed projects (Classic), is there any thought given to allowing certain fields that exist in the Jira Software Platform to be shared and used on Jira Product Discovery?
Non Custom Fields:
In a way, I love the simplicity offered here so I wouldn't be asking for all Custom Fields to be available but I am sure there are companies out there that do use certain custom fields on everything.
Custom Field that we end up using AS EXAMPLES:
Hi Erin, thanks for the feedback.
Unfortunately the ability to share project configuration, including fields, is something that is only supported in company managed projects - not team-managed projects (and Jira Product Discovery was created as a team-managed project)
Eventually this will be possible, but for now you need to replicate fields like this across projects.
Just a thought: I wonder if it would be possible to automate this using Automation4Jira? I've never tried but will give it a go next week
Automation will work to make sure the fields get set but it still leads to duplication of creating and maintaining the fields which is the not so great part.
I have the same concern and would really like to share fields between Jira discovery and Jira Software that would ease sync between the two products.
I'd second this. I ran into the same issues as we have Client fields and some others and when moving those in as Ideas they just get lost. We can recreate them but they do become inconsistent
Also, given Discovery is very much not a team only thing it should really be designed company first I would think
There are parts I love about it being next-gen (Team) because it is simplified but the same reasons we don't use next gen for some projects and not others exists. Most large companies are using Company projects. I am hoping this is just because it is Alpha. Wondering if this will be its own application in the end or remain as a template?
