How do I create a Weighted Shortest Job First set-up on my JPD project
Deleted user July 31, 2023
I want to create a Weighted Shortest Job First set-up on my JPD project but I am struggling:
Fields:
  • CUSTOMER / BUSINESS VALUE
  • TIME CRITICALITY
  • RISK REDUCTION / OPPORTUNITY ENABLEMENT
Field set-up
  • 'Select field'
  • 1, 2, 3, 5, 8, 13, 21
Calculated field:
{CUSTOMER / BUSINESS VALUE} + {TIME CRITICALITY} + {RISK REDUCTION / OPPORTUNITY ENABLEMENT} / EFFORT
It looks like the calculated field cannot be calculated using 'Select field' options. Any tips on how to work around this 🙏 👨‍💻
2 accepted
3 votes
Chris Timms
July 31, 2023
Hi @[deleted]
I think you can achieve your desired outcome by adding weight to each value in the selected field?
The weight of a value can then be used in calculations.
- C
Tried it out and it works thanks!
CC
July 31, 2023
We do WSJF as well.  I had to add the values as "weights".  Then it will calculate.  I meant to send this in as a bug.  You can't use the number field type to calculate.  JDP thinks its text and not a number.  For example, if the number is 5 it will calculate as if it is 1.
Nice it works!! Thank you.
