How do I fix the results in the Project Start and Project Target field in Confluence widget?
Angelique Kim
Mart Postma
January 28, 2024
Hi @Angelique Kim
Unfortunately, you can't. This is a known bug (https://jira.atlassian.com/browse/JRACLOUD-79936) within JPD caused by a different date formatting method in a team-managed project than the typical date fields you might know from Jira/Confluence.
Doesn't look like they will fix it soon though...
Reply from support to my bug report: "Since resolving this issue requires a fundamental code change within Atlassian Cloud itself, it may take some time for the fix to be deployed. Unfortunately, we don't have an estimated time of arrival (ETA) at the moment. As a result, there isn't much we can do as support within the scope of this case. Any future updates regarding the fix will be provided by our Development Teams."
