How to make other fields than Idea title be visible in list, roadmap and timeline views?
Tatiana Torset
It looks like a trivial question, but i am struggling to figure out how to show more details on an idea in different views.
So I have this:
And I want to have something like this:
Can someone point me to the correct place to look this information up please?
4 votes
Nick Haller
March 15, 2024
Hi @Tatiana Chernogorova ,
The fields that show on the ideas' cards will depend on the fields selected within that view.
For example:
Having said that - if a field does not have a value entered it may not display on the card until a value is entered (such as the CF1 field in the screenshot above - this shows for one card because a value is entered, but the field does not appear on others since no value is entered).
I would also suggest having the Card layout set to Detailed which might be more visually and aesthetically pleasing:
Sergio Grisa March 15, 2024
Quando você utiliza visualização por quadro, o card pode conter qq campo.
Brittany White March 15, 2024
I have found that when I'm in a timeline view, selecting Fields at the top, allow me to choose what gets included within a view:
So you in your case, select the Summary, Idea Short Description, Goal and Impact Score and it should show.
