It looks like a trivial question, but i am struggling to figure out how to show more details on an idea in different views.
So I have this:
And I want to have something like this:
Can someone point me to the correct place to look this information up please?
The fields that show on the ideas' cards will depend on the fields selected within that view.
For example:
Having said that - if a field does not have a value entered it may not display on the card until a value is entered (such as the CF1 field in the screenshot above - this shows for one card because a value is entered, but the field does not appear on others since no value is entered).
I would also suggest having the Card layout set to Detailed which might be more visually and aesthetically pleasing:
Quando você utiliza visualização por quadro, o card pode conter qq campo.
I have found that when I'm in a timeline view, selecting Fields at the top, allow me to choose what gets included within a view:
So you in your case, select the Summary, Idea Short Description, Goal and Impact Score and it should show.
