Is it possible to add dependencies to Ideas?
jordan.zarate November 18, 2022
Is it possible to add dependencies on Ideas (e.g. this Idea is blocked by these Ideas)?
This would help our Product Managers provide more context around the work planned around Ideas. Thank you!!
3 votes
Peter Heidorn
It’s there and the linking works great.
blocked by, blocks, related to etc etc. it’s a great feature.
I also like being able to link other confluence docs in the description field using the attachments.
jordan.zarate November 21, 2022
Ah, I must have missed that link issue button in JPD. Love that it works the same way it does in other Jira projects. Thank you @Peter Heidorn
Erin Mihalik
Regular linking works so as long as you have link type set up for dependent, should work.
Thanks so much @Erin Mihalik!!
