As far as I know, the C2C tooling does not yet support JPD
The JPD team seems to be working on this feature. It's not possible right now.
Yes you are correct on both fronts 👍
Would it be possible to export to CSV and use a CSV importer in another instance to restore?
hi there! it's in our roadmap! so stay tuned for updates in this area.
What is leading you to need to move JPD ideas between sites? we are curious to learn about why customers find themselves with this need.
Thanks!
Amina
For the same reasons any other projects or Confluence spaces would be moved - generally merges and consolidations.
Sometimes people build things in sandbox environments as well.
