Is there a way to migrate Jira Product Discovery projects between cloud sites?
Rob Horan
December 2, 2024
As far as I know, the C2C tooling does not yet support JPD
Jens Schumacher - Released_so
The JPD team seems to be working on this feature. It's not possible right now.
Tanguy Crusson
December 3, 2024
Yes you are correct on both fronts 👍
Rob Horan
December 11, 2024
Would it be possible to export to CSV and use a CSV importer in another instance to restore?
Amina Bouabdallah
December 3, 2024
hi there! it's in our roadmap! so stay tuned for updates in this area.
What is leading you to need to move JPD ideas between sites? we are curious to learn about why customers find themselves with this need.
Thanks!
Amina
Rob Horan
December 3, 2024
For the same reasons any other projects or Confluence spaces would be moved - generally merges and consolidations.
Sometimes people build things in sandbox environments as well.
Like Jonathan Tang likes this
