I've found that the "linked issues" field (the count) does not appear on an idea card when I turn on the filter on a board of ideas. I've tested adding/removing as well as showing/hiding but still no result. The only change is the height of the cards adjusts as if the UI is making room for the element to be shown but it does not appear within the card.
Other fields like "created" and "comments" do appear on the cards when I add them to the board.
I've reported this to Atlassian and they think it's a bug. Just wanted to share here in case anyone else notices this behavior.
Thanks!
Matt
Thanks for reporting this! We've managed to reproduce the problem and fix it. It should get to production tomorrow or so.
Got a similar issue, but with the Linked Issues Count field to show in the backlog. The value is shown for some Issues but for other, in thesame board, of the same issue type, it is not.
The Linked Issue Count has been added to all issue type screens andd it is not marked as Hidden in the field configuration.
Any ideas anyone?
I did test this, and found the same in both the timeline view, and the board view.
It worked fine in the list view though.
Strange!
Ste
