Power Automate - Jira Connector error
Thibaut Saillant
April 14, 2023
I started to work with Jira connector in Microsoft Power Automate to create issues.
I'm properly connected to the Jira account using a Token but get this error when trying to create an issue. Does anyone have an idea on how to fix this?
I found a post that says I should remove the reporter field from the issue template in Jira but I don't have this option in the project settings.
Eric Duncan
July 20, 2023
I'm seeing the same error even with a newly-created Product Discovery project and the newer v3 action. I just opened a ticket with Power Platform support and they claim it's not an issue with the connector and actually an issue with the API.
Did you ever find a workaround to creating an issue?
chad.leblanc
So there's a quick way to do it and its to remove the permission in Jira (for the user of the API token creating the flow) to set a reporter.
Once that is removed, this error goes away.
You can also try making sure that the Reporter field is always available and automatically assigning a user to it.
Like Steffen Opel _Utoolity_ likes this
