Product Discovery Slack integration does't work
RS
December 22, 2024
Hi!
I tried to provide a Slack integration for Jira Product Discovery, but it showed me an issue.
Does it mean, the integration is not available on the Free plan of Product Discovery?
Nick Haller
December 23, 2024
Hi @RS ,
We've seen some customers run into this issue where the Slack app is not installed correctly for JPD. You will want to open a ticket with JPD support so they can resinstall the app. This only takes a few moments, but can only be corrected with their assistance.
You can open a ticket HERE, or within JPD under the Give feedback tab >> Get help from the support team option.
RS
December 23, 2024
@Nick Haller hi!
Thank you for your reply!
Unfortunately, I can not open a ticket, because my JPD has a free plan. Maybe, you can raise the ticket somehow? Thank you!
