We started using product discovery for 2024 roadmap planning.
We have roughly ~35 PMs contributing and managing their roadmap deliverable out of PD.
Naturally we have many views of the same data based on filters and what any one audience would want to see. That is one of the main value props of discovery.
We have maybe 3 or 4 calculated columns, vs Coda where we literally had 100s.
We have gotten to the point where every single click takes minutes to refresh, its basically un-usable and need some sort of solution forward. I have been deleting unused views but nothing seems to be helping.
Unsure what number the sequence starts on, but we are approaching ID 17,000
Any ideas?
Are all being managed in a single PD project? If so, you may want to consider making divisions among PM groups and opening/managing other projects.
I’ve recently started building my JPD project board, which I plan to present to our team in the coming days. Currently, I’ve added just over 100 product ideas to the board. However, as I’ve been populating and organizing the content, I’ve encountered noticeable performance issues. These include significant delays when loading pages, transitioning between columns, and updating the status of items.
Would you recommend that I go ahead and create a support ticket to have your team investigate this further?
Yes please @Nadia Ferguson !
Hi @Chris Carafello , I've asked the team to investigate.
Am I reading right that you have 17,000 product ideas???
Oh, one thing that will help @Chris Carafello would be to give us access to your projects so we can test there directly and offer suggestions. That makes things 10x faster.
To do that you'd need to raise a support ticket.
From Jira Product Discovery:
That will create a support ticket and a support person will reply for permission to access your instance.
Our ID is 17,000 but it was artificially increased due to many failed imports that increased the count.
I had the same problem working on a Thinkpad with i7 (windows/chrome). I switched to Firefox and the performance improved somewhat. I'm now working on a macbook air and it's running very smooth in large JPD projects. My colleagues that are running windows still have some issues tho.
So for me the solution was to switch to apple.
I've noticed the same latency starting to creep in... just added roadmaps for ~35 product teams. Praying scalability isn't an issue as we really like the platform.
I am sure its related to volume, multiple views, and grouping.. however that is literally the use cases for why we are using it.
We have a team dedicated to things like this. We've done a lot of improvements over the past months on these topics, I thought the same initially but we found it isn't as simple as what you suggest Chris - usually it's due to a combination of things that are configuration specific (e.g. specific formula calculations) or concurrent usage coupled with real-time updates (which we're revamping). Which is why looking at your instance will help
Tanguy,
I have given you access following the steps you listed. Please let me know next steps, PMs are all reaching out to me about slowness.
Thanks! I've asked the support team
