We've randomly seen JPD ideas display the Delivery Status field on the right side pane with the text in a popout message: "We could only calculate the delivery data partially, because you've hit the 500 sub-issues limit."
These issues do not have 500 epics (or epics+subtasks) linked to them. Is this 500 epics+tasks+subtasks for all ideas in JPD?
Are there currently any issues with extending the limit?
Hi @Seth Mason
We had to implement a limit because some users had 10000 linked issues in delivery and this was causing a 429 error for them limiting their access to Jira Software.
The limit applies to the Jira Product Discovery project, not per idea.
If you haven't encountered any issues with accessing Jira Software we can disable this limit for you. If you want to proceed with that, please provide your site name.
Best,
Hanna
I don't have 10k linked epics/issues from JPD. I'm not running into any other issues beyond this popup. How can I DM you my instance or can you just pull it from my email address?
@Hanna We are going to need that limit removed or changed. I only have 10 ideas in here yet I am encountering the error.
I think people hitting over 10k is going to happen easily if Subtasks are included. One could make the argument that Subtasks should be filtered out in Delivery and only standard issue level or higher is returned. As a product leader, this is not where we will run scrum off of so understanding the subtasks is not 100% necessary.
50 Ideas in here with one epic each = 50 issues plus potentially 9 user stories in each epic is immediately 500.
May you please disable this on appetize.atlassian.com and spoton.atlassian.com?
Hi @Erin Mihalik
We'll disable this limit for the provided sites.
Hi @Seth Mason
Feel free to share the site name here or DM it to hsazonava@atlassian.com.
Hi @brent_johnson
It's now disabled for your site. (sorry for the delay, just got from a leave).
Best,
Hanna
Hey @Hanna
Could you please remove this limit from rccl-idd.atlassian.net?
We are realizing we hit this 1000 sub-issue limit very easily.
Andrew
Hi @Andrew Durden
We have removed the limit for the respective site.
Cheers!
Hi Hanna,
I've come across the same issue, is there a way to turn this off by now?
BR, Benedict
Hi @Hanna,
Can we also please have this limit removed from our site - connectrn.atlassian.net?
Thanks!
-Andrew
Hi @Andrew Dunn
The limit was disabled for connectrn.atlassian.net.
Cheers!
Hi @Benedict Lubik
It's possible to disable the limit. If you'd like to proceed with disabling, please share the site name.
Cheers!
@Hanna we are still experiencing the limit in Product Discovery. Are there specific steps we need to take to have the limit fully removed?
Hi @Andrew Dunn
This might be related to the current work and a bug the team uncoverd, see details in the thread https://community.atlassian.com/t5/Jira-Product-Discovery-questions/1000-Sub-issues-limit/qaq-p/2341506.
We expect it to be solved in the next weeks.
Hi @Holly Holbrook
Could you share the message you get in the UI about the limit?
It might be related to the work described in the thread here https://community.atlassian.com/t5/Jira-Product-Discovery-questions/1000-Sub-issues-limit/qaq-p/2341506.
@Hanna Please disable it for https://i3dhub.atlassian.net/. I don't expect that we will see any issues since we don't exceed it by that much.
Thanks!
@Hanna I'm getting this error. I think you're right :) "We could only calculate the delivery data partially, because you’ve hit the 1000 sub-issues limit."
Hi @Benedict Lubik
The error you see is related to the bug we identified. You'll see this error even if you don't hit the 1000-issue limit. It's going to be fixed soon.
Find more details here in the thread https://community.atlassian.com/t5/Jira-Product-Discovery-questions/1000-Sub-issues-limit/qaq-p/2341506.
But this should only be "per each idea" not per JPD instance.
We do not have any JPD ideas linked to issues higher than epic.
