We have an integration between Help Scout (our support platform) and Jira Software. Our support team creates Jira issues in a specific project and we track the number of linked support issues. These would be prime candidates to add to Jira Product Discovery ideas as links - I know when I paste the entire link, I can link it that way and two-way link is created. it would be great if I could also just type jira issue key and it expanded the way jira software comments recognize it's a jira key you just typed.
Hi Zuzana,
Where would you like to type the Jira issue key?
This is how Jira Product Discovery works with Jira issues today for prioritization: Video demo
Hi Tanguy,
I have a similar problem where I have thousands of tickets residing in Jira that I need to import and attach to Ideas within JPD. Thank you for making this video. I think this is helpful.
Your bulk migration tool in JPD could use some improvement though. I find it odd that it uses a CSV file to import when more commonly, I'm moving existing Jira tickets from other Software Dev Jira Projects into a JPD Ideas list.
Hi @Jonathan Hau , I'm not sure I understood your feedback: have you tried moving existing Jira tickets to Jira Product Discovery using bulk issue move? That should work.
Oooh I get it - you want to create new ideas AND attach existing tickets to them. hmm, yes, we don't have a good way to do that.
