Are votes going to be publishable?
Andy Betts November 8, 2024
We've been using JPD for a while now and absolutely loving it. It's giving us a much clearer view on what product are doing and why, far better than the last tool we were using.
One slightly frustrating thing though.....
We have a created a customer ideas portal using a view and it works billiantly. However, we are having to share this by allowing customers direct access to the project as publishing the ability to vote is not supported.
Are there any plans to allow this?
Nick Haller
November 8, 2024
Hi @Andy Betts ,
Not sure if/when vote fields will be supported with Published views, but I'll get this feedback shared with engineering and product. Can't really think of a workaround either since vote fields are not support with automations either :/
Maybe using another field to represent the total votes such as a number field as a visual, but I know that's additional work / effort, and doesn't provide much especially since when a vote is casted, a comment / description can be added.
Thanks @Nick Haller much appreciated!
We have applied for EAP last week as I think we can use the enahnced permissions to get what we need. I'm not sure how long that takes though but for meantime we will just delete the views from the project we don't want people to see.
Matt
April 6, 2025
@Andy Betts - Were you abel to get this working? I'm running into a similar roadblock.
Like Mark T likes this
