Automatic linking between tickets in JIRA and Jira Product Discovery
Selina Wong February 24, 2025
I've created an automated rule to automatically create a ticket to a separate JIRA board once a field value has changed. However when that ticket is created, it's not automatically linked in the JPD idea as a delivery. Can this be done?
For example:
Field value changed -> Work Required -> Automatically create a ticket to separate JIRA KANBAN Board. This can be done.
But im discovering that the ticket created in the KANBAN board is not automatically linked to the original idea in JPD. Can i do this? I would like it to be automatically linked and therefore the progress status be automatically updated in JPD board.
Gary Spross
In your automation rule, when creating the ticket within the Jira ticket, you can link it to the Idea ticket within the JPD project using the "Polaris issue link" link type. From the Jira ticket, the linking would be "is implemented by".
Hey @Gary Spross thanks for the response. Did you mean creating the automation rule on JPD itself or in the Kanban board? I have tried and wasn't able to find a "Polaris issue link" I have managed to just automatically link the issue however it's not linked as a delivery ticket.
Screenshot 1 (initiative 4) is automatically linked to the JPD idea as a linked issue but not delivery issue and screenshot 2 (initiative 1) is when i manually add the link of the ticket created in the Kanban board. I was wondering if we can automatically link it so that it shows as a delivery ticket?Screenshot 2025-02-24 at 16.00.07.pngScreenshot 2025-02-24 at 16.00.48.png
Gary Spross
Your linked issue, URPR-9 is linked using the "relates to" link. It would need to be linked using the "is implemented by" link.
In the automation rule you have that is creating the "delivery" ticket within the Jira project, you can add the "Link issues" component like this:
NOTE: I'm assuming the trigger for the automation is a field being updated within the JPD Idea ticket, so using the "Trigger issue" in this component should work.
I've tried this but it hasn't worked. It hasn't linked the issue at all when I used "is implemented by" instead of related to. Any thoughts?
Gary Spross
Hmmm...
For me, it shows within an Ideas panel on the Jira ticket, like this:
and within the Delivery panel on the JPD Idea ticket, like this:
Selina Wong February 25, 2025
I tried again today and this works now ! Thank you. Probably a glitch yesterday. Tried the exact same thing but it's linked as delivery tickets now. Thanks again for your help :)
Like Gary Spross likes this
