Can I track the Idea progress using a Release from Jira Software?
Thiago Pinheiro
I just started using JPD and noticed we can track the delivery using other cards/issues from Jira Software. I started using epics for that but it does not fit in our scenario since a deliverable from JPD does not match the Epic items, because, our items being delivered in a version/release might be in different epics.
So can we link a release to a JPD Idea for tracking the delivery ?
Rohan Swami
March 4, 2024
Hi @Thiago Pinheiro thanks for your question.
I'm curious about how you would like this to work. Would you like to link an idea to a version/release as an alternative to epics? For example if an idea has 2 releases, do you want the delivery progress bar you see for that idea to aggregate the delivery progress across those 2 releases?
Thiago Pinheiro
Exactly! I haven't thought about multiple releases, but I suppose it would be helpful, in the same way that we can link multiple epics/issues.
Rohan Swami
March 5, 2024
@Thiago Pinheiro thanks, I've recorded your feedback for our future reference.
Like Thiago Pinheiro likes this
marian_nedelchev
July 29, 2024
@Thiago Pinheiro , this is a very good request. Do you have any feedback about it?
Andy Nortrup
I haven't tested, but you can track a date to a date on the implementation issues. Those issues can have dates assigned by the fix version. So I think in a roundabout way you can.
Nate Whitehead
I could see this being very beneficial - or even being able to connect a JPD project's custom field to an Asset object to support a dropdown list of values. If you could do that, you could potentially have an asset schema to support versions that projects could 'opt' into.  Now I need to go see if I could do this either directly or with automation. Good question though @Thiago Pinheiro , interested to hear how others solve this.
Thiago Pinheiro
The problem that I see using a custom field is that it won't provide the delivery progress bar neither the delivery status like the image below:
Lisa Kostyshak March 4, 2024
@Nate Whitehead  I'd be very interested if you find a way to connect an asset object to JPD. From what I understand, it is currently not supported, but would be very helpful to our team.
